Output constant current level can be adjusted by applying one of the three methodologies between DIM+ and DIM-:
0 ~ 10VDC, or 10V PWM signal or resistance.
Can i use one of the 12 the PWM open collectors from the 4AO to dim the LED PSU, or do i need to use the 0~10V analog signal?
Link to PDF datasheet: NPF-60D-12 LED driver
