Page 1 of 1
4AO extension and PWM for dimmable LED driver
Posted: Sat Sep 10, 2016 10:46 pm
by Havor
Hi i have a MeanWell led power supply that can be controlled in 3 ways.
Output constant current level can be adjusted by applying one of the three methodologies between DIM+ and DIM-:
0 ~ 10VDC, or 10V PWM signal or resistance.
Can i use one of the 12 the PWM open collectors from the 4AO to dim the LED PSU, or do i need to use the 0~10V analog signal?
Link to PDF datasheet: NPF-60D-12 LED driver
Re: 4AO extension and PWM for dimmable LED driver
Posted: Mon Sep 12, 2016 7:39 am
by tomas_hora
Hello, yes I think it might work.
