Unipi + 1W-8R
chrigui
Re: Unipi + 1W-8R
Postby chrigui » Mon Dec 07, 2015 9:38 am
ok,
the bad news: i was editing the wrong file the.
the good news there is progress, i edited /etc/evok.conf and then i ran:
Code: Select all
sudo python /opt/evok/evok.py
and i got this:
Code: Select all
Listening on port: 88
UniPi version:1.1
104
Error in config section RELAY_9 - No option 'mcp' in section: 'RELAY_9'
Error in config section RELAY_10 - No option 'mcp' in section: 'RELAY_10'
Error in config section RELAY_11 - No option 'mcp' in section: 'RELAY_11'
Error in config section RELAY_12 - No option 'mcp' in section: 'RELAY_12'
Error in config section RELAY_13 - No option 'mcp' in section: 'RELAY_13'
Error in config section RELAY_14 - No option 'mcp' in section: 'RELAY_14'
Error in config section RELAY_15 - No option 'mcp' in section: 'RELAY_15'
Error in config section RELAY_16 - No option 'mcp' in section: 'RELAY_16'
Entering measure loop
Entering 1wire loop
Converting in progress
i went online: 192.168.1.3:88 and only relay 1 was showing
tomas_hora
Site Admin
Re: Unipi + 1W-8R
Postby tomas_hora » Mon Dec 07, 2015 9:58 am
Now you will figure it out by yourself... Just make sure that you have the 1WRELAY not RELAY
chrigui
Re: Unipi + 1W-8R
Postby chrigui » Mon Dec 07, 2015 10:06 am
IT WORKED!!
thank you so, Tomas, you have no idea how happy i am.!
i will disappear for few days (to forget how annoying i am) and come back with more questions if thats ok.
thanks again!
Return to “UniPi Extension modules (official)”
Who is online
Users browsing this forum: No registered users and 1 guest
