Using a Realtek 802.11n dongle with Unipi
killua
Postby killua » Thu Nov 27, 2014 3:08 pm
Setting up some Unipi's to talk to a central (HA/scalable) server here. Since wired as well as wireless connection to the unipis was required, we got a few Realtek wifi dongles. Follows a braindump to recall it later and free for anyone else to use.
Lets get the kernel modules first:
Code: Select all
wget http://www.mendrugox.net/downloads/20 -O raspi
scp -r raspi pi@192.168.2.222:~
SSH into the RPi and to load the module
Code: Select all
sudo su
cd raspi
sudo cp *.ko /lib/modules/3.12.28+/kernel/drivers/net/wireless/
sudo cp *.bin /lib/firmware/rtlwifi/
sudo depmod -a
sudo echo 8188eu >> /etc/modules
sudo modprobe 8188eu
Now, we want the RPi to acquire a fixed IP (192.168.2.222) when connected to LAN and use the GW 192.168.0.1 and we also want the RPi to lease an IP from DHCP when wifi dongle is connected to it. To do this, we want to change /etc/network/interfaces accordingly:
Code: Select all
sudo echo '
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.2.222
netmask 255.255.255.0
gateway 192.168.0.1
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
' > /etc/network/interfaces
We need to setup wpa supplicant. Assuming your wifi has the ssid "MYSSID" and password "YOUSHALLPASS", then
Code: Select all
sudo wpa_passphrase MYSSID YOUSHALLPASS
whcih reutrns
Code: Select all
network={
        ssid="MYSSID"
        #psk="YOUSHALLPASS"
        psk=74d000273e94452d31a3e0ec32d87b8ac52dd3e31f1448a41b8d98ea99abafa0
which you need to put into your wpa_supplicant.conf. The complete conf file looks like this
Code: Select all
sudo echo '
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
        ssid="MYSSID"
        #psk="YOUSHALLPASS"
        key_mgmt=WPA-PSK
        pairwise=CCMP
        auth_alg=OPEN
' >  /etc/wpa_supplicant/wpa_supplicant.conf
To prevent the dongle to go to sleep whenever you don't need it, disable power management:
Code: Select all
sudo echo '
# Disable power management
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0
' > /etc/modprobe.d/8188eu.conf
If you still get random disconnects, get closer to your AP (that actually helped, the dongle is crap when it comes to signal strength). Hope this helps.
Return to “Tutorials”
Who is online
