installing evok manually
spudgunman
Postby spudgunman » Sun Jun 21, 2015 10:37 am
if you are like me and found the install-evok.sh to not be acceptable to your environment here is the quick and dirty you need to know. it would be nice if this team opened the wiki documentation and let people make this product better documented rather then just posts.
First get I2C working - this assumes your Pi is updated and running 1.3 kernel
Code: Select all
sudo nano /etc/modules
add the following on separate lines in the file.
Code: Select all
i2c-bcm2708
i2c-dev
Open boot config.txt
Code: Select all
sudo nano /boot/config.txt
add the following
Code: Select all
dtparam=i2c1=on
dtparam=i2c_arm=on
save, then..
Code: Select all
sudo reboot
once back in your Pi will this command return a big matrix of numbers?
Code: Select all
sudo i2cdetect -y 1
if you see something like this below.. your track, you cant continue if you don't see this specifically that 20: 20 is important
Code: Select all
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- 18 -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
that worked correct? if not go fix it...
install and get the unipi evok package
first, if you dont have git
Code: Select all
sudo apt-get install git
now git the evok project and put it in your home directory
Code: Select all
cd ~
git clone https://github.com/UniPiTechnology/evok
get some foundation applications
Code: Select all
sudo apt-get install -y python-ow python-pip
sudo pip install tornado toro jsonrpclib
make and install PiGPIO from source
Code: Select all
cd~
git clone https://github.com/joan2937/pigpio PIGPIO
cd PIGPIO
make
make install
'install' the files into the OS
Code: Select all
cd ~/evok
sudo cp -r tornadorpc_evok /usr/local/lib/python2.7/dist-packages/
sudo cp -r evok/ /opt/
sudo mkdir -p /var/www/evok && sudo cp -r www/* /var/www/
sudo cp etc/evok.conf /etc/
sudo cp uninstall-evok.sh /opt/evok/
create services and set script executable
Code: Select all
sudo cp etc/init.d/evok /etc/init.d/
sudo cp etc/init.d/pigpiod /etc/init.d/
sudo chmod +x /etc/init.d/evok
sudo chmod +x /etc/init.d/pigpiod
sudo chmod +x /opt/evok/evok.py
set the services to start
Code: Select all
sudo update-rc.d pigpiod defaults
sudo update-rc.d evok defaults
you should go edit the ecok.conf because it uses port 80 by default and you dont want that
Code: Select all
sudo nano /etc/evok.conf
find the "port = 80" and change it to something like "port = 8181"
start the services now
Code: Select all
sudo service pigpiod start
sudo service evok start
then load up a browser and if you used my recommendation browse to http//PI.IP:8181
now you can mess around with it a little and see that you did something
next you likely want to read up on https://github.com/UniPiTechnology/evok#api-examples
rudyvan
Re: installing evok manually
Postby rudyvan » Sat Oct 10, 2015 10:40 pm
i did the manual installation, step by step as detailed.
The board is listed in the I2C, the services are started, but when i use a browser to approach the board i got the following message:
ERR_CONNECTION_REFUSED
Any idea why that may be?
when i use the Python using JsonRPC program example, i get a similar error (see below):
extract:
s.relay_set(1,1)
File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 639, in __call__
return self.__send(self.__name, args)
File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 523, in _request
response = self._run_request(request)
File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 556, in _run_request
verbose=self.__verbose
File "/usr/local/lib/python3.4/xmlrpc/client.py", line 1131, in request
return self.single_request(host, handler, request_body, verbose)
File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 361, in single_request
self.send_request(connection, handler, request_body, verbose)
File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 400, in send_request
self.send_content(connection, request_body)
File "/usr/local/lib/python3.4/site-packages/jsonrpclib/jsonrpc.py", line 425, in send_content
connection.endheaders()
File "/usr/local/lib/python3.4/http/client.py", line 1086, in endheaders
self._send_output(message_body)
File "/usr/local/lib/python3.4/http/client.py", line 924, in _send_output
self.send(msg)
File "/usr/local/lib/python3.4/http/client.py", line 859, in send
self.connect()
File "/usr/local/lib/python3.4/http/client.py", line 836, in connect
self.timeout, self.source_address)
File "/usr/local/lib/python3.4/socket.py", line 509, in create_connection
raise err
File "/usr/local/lib/python3.4/socket.py", line 500, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused[/code]
tomas_hora
Site Admin
Postby tomas_hora » Mon Oct 12, 2015 7:41 am
try shutting the evok service down by service evok stop or by kill command with the process id. Then run /opt/evok/evok.py and past the output here so we get more detailed info...
rudyvan
Postby rudyvan » Tue Oct 13, 2015 5:07 pm
Dear Tomas,
i am working with python3.4 and therefore issues with evok.py because i think my 2.7 environment is not default env.
I will start from a fresh debian install and first get evok running before i try installing python3.4.
Should i have problems, then i come back online.
Kind Regards,
Rudy
rudyvan
Postby rudyvan » Tue Oct 13, 2015 9:01 pm
Dear Tomas,
took a fresh install from debian (2015/09/24) and it worked :D !
#had to deviate from yr installation script as follows:
#had to install the i2c-tools:
sudo apt-get install i2c-tools
#had to add sudo:
sudo makefile # for pigpiod
Rudy
chuckhinds
Postby chuckhinds » Sat Feb 13, 2016 4:52 am
Dear Rudy and Thomas,
I has a similar problem with tornado, toro, and jsonrpclib getting loaded into Python 3.5. I got around this problem by changing the following line in install-evok.sh file:
"pip install tornado toro jsonrpclib"
to
"/usr/bin/pip-2.7 install tornado toro jsonrpclib"
It forced the install to Python 2.7 libraries
I updated build-essentials and python-dev for 2.7 (and all other versions) first:
"sudo apt-get install build-essential python-dev"
Return to “Tutorials”
Who is online
Users browsing this forum: No registered users and 1 guest
