Sensor
est
Sensor
Postby est » Wed May 25, 2016 11:22 am
I follow the tutorial in youtube and mervis IDE doesn't dectect the sensor even if I put the UNIPI to commisioning mode.
Thank you in advance.
tomas_hora
Site Admin
Re: Sensor
Postby tomas_hora » Wed May 25, 2016 2:10 pm
Can you provide more info? Is the sensor connected directly to UniPi? Have you compiled and deployed the project with the 1wire bus to the UniPi...?
est
Re: Sensor
Postby est » Wed May 25, 2016 3:44 pm
Yes the sensor connected directly to UniPi
No how to do thant ? Is that in the video tutorial ?
tomas_hora
Site Admin
Re: Sensor
Postby tomas_hora » Wed May 25, 2016 4:09 pm
Yes, around 04:00 min time: https://www.youtube.com/watch?v=I3AFm-TVSt4 and also in the documentation in pdf at http://downloads.unipi.technology
est
Re: Sensor
Postby est » Wed May 25, 2016 4:16 pm
Yes I did exactly what it did for the 1Wire in the video but after the commisioning it said "Selected channel doesn't exists in PLC" so doesn't detect the sensor.
tomas_hora
Site Admin
Re: Sensor
Postby tomas_hora » Thu May 26, 2016 7:17 am
Sorry there is a small bug in the video. You need to build the project and deploy it to UniPi before you can attach the sensors....
est
Re: Sensor
Postby est » Fri May 27, 2016 2:06 pm
Okay so how to deploy the project to UniPi ? I don't find and when I build there are some errors
tomas_hora
Site Admin
Re: Sensor
Postby tomas_hora » Mon May 30, 2016 8:00 am
To be able to build and deploy the project to the UniPi you have to fix all the errors. The video has been updated so see that https://www.youtube.com/watch?v=PymuUoXXqGQ
If you are having troubles, download the default project from the examples archive at http://downloads.unipi.technology
todward
Re: Sensor
Postby todward » Wed Jun 08, 2016 9:36 pm
Tomaš, a question regarding this Sensor topic: I need to integrate three 1Wire DS18B20 sensors in Mervis. I did follow the tutorial and did add three devices to the 1Wire channel instead only one device like in the tutorial. But after plugin the sensors I see only the parameters for one sensor in Mervis (I did boot the Raspi with a different image containing Evok for verfication, Evok shows all three sensors correctly).
Should I configure 1Wire devices in Mervis one after another?
Matthias
...and is there a documentation for the default function blocks in Mervis?
tomas_hora
Site Admin
Re: Sensor
Postby tomas_hora » Fri Jun 10, 2016 7:18 am
Hello Mathias, did you use assign sensor or detect sensor? If you have the UniPi in commisiong mode you can also use detect sensor on the 1Wire bus from where you should see all three sensors on the bus and if you select it, it should be automatically added to the channel.
The documentation is in the About->Help (or press F1 on when the function block is selected).
Return to “Mervis”
Who is online
