Suggestions to make this product even better!
ewillems
Postby ewillems » Thu Nov 27, 2014 10:22 pm
Just want you to give some suggestions to make the Unipi even better! First, thanks for this great development board. It makes it really easy to connect external devices.
- It would be great if you add some GND connectors (use an alternate color, like the current 12V connector). This makes it easier to connect external devices
- Add a 5V power supply to the shop and to the UniPi complete set.
- Add extra (alternative) connectors for 5V power supply, so there's no need to search for an exact matching power supply connector.
- Plastic housing, fitted for Din Holder
tomas_hora
Site Admin
Re: Suggestions to make this product even better!
Postby tomas_hora » Thu Nov 27, 2014 10:41 pm
Thanks a lot for your tips!
We are still accepting ideas for future versions so any suggestions are welcomed :)
We want to add the 5V power supply, but we just cannot find any power supply with universal plug EU vs US... So we will at least provide the power supply with European plug and later other version.
The connector is a tough one :) We are still counting pros and cons...
We really wanted to provide the plastic housing but we do not have any experience with this... So again, any suggestions, contacts, tips are welcomed.
Thanks a lot again!
mrvn
Postby mrvn » Thu Dec 04, 2014 1:19 pm
* Include a serial adapter with RJ11 and USB connectors in the shop
* Include Battery in the shop
* Add pins for the serial so the common RPi serial adaptors can be used
* Extending on the above: Add the full pin rows identical to the RPi one with all unused pins routed through. It should be possible to connect another module like the PiFace display: http://www.element14.com/community/docs ... =sjymv0fpI . Would be great to give manual control without the need for a smartphone or computer to connect to the RPi.
* Alternatively design a T connector that can be put between the RPi and another module and also connect to the UniPi
BlackSoll
Postby BlackSoll » Sun Apr 10, 2016 10:35 am
tomas_hora wrote:We really wanted to provide the plastic housing but we do not have any experience with this... So again, any suggestions, contacts, tips are welcomed.
Please let me give a suggestion !
I was looking for a din rail enclosure for my unipi and i have found this one :
https://www.okwenclosures.com/en/Railtec-B/B6506121.htm
Looks promising.....Anyway i'm gone try it and send feedback. Also i have found a company at Czech Republic with a lot of plastic housings incuding this one.
http://www.okatec.cz/
Don't know if version 2 of unipi will remain in the same dimensions, but it would be great if we have an enclosure like this as an option.
philipp
Postby philipp » Thu Jun 09, 2016 2:36 pm
BlackSoll wrote:Please let me give a suggestion !
tomas_hora
Site Admin
Postby tomas_hora » Fri Jun 10, 2016 7:37 am
We do not plan to make a case for the UniPi v1.1 except the cover & holder that is already available...
BlackSoll
Postby BlackSoll » Fri Jul 01, 2016 9:17 pm
Just an update for a din rail enclosure.
I have found a common standard DIN rail 35mm enclosure in 2, 4 and 9 units for electronic devices at thingiverse.com and i'm thinking to modify it to unipi dimensions so i can fit it inside.
Haven't found the time to do it yet, cause my skills at 3d drawing are poor, so i'm posting it here if someone can help with it.
Here are the files if someone is interested:
Code: Select all
http://www.thingiverse.com/thing:535347/zip
Return to “General discussion”
Who is online
