UniPi and pi4j
George Proost
UniPi and pi4j
Postby George Proost » Sat Oct 10, 2015 2:44 pm
Hi all,
I would like to build an extension to the pi4j library, and am doing some tests:
UniPi + Rasp 2 + raspbian
I cannot seem to get relay 1, GP07 to work. There is somethig I missing here, but whar is it?
I have confirmed that I have address 20 for the MCP23008:
Code: Select all
pi@raspberrypi ~ $ i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 51 52 53 54 55 56 57 -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- 6f
70: -- -- -- -- -- -- -- --
I can use:
Code: Select all
i2cset -y 1  0x20 0x09 0x80
to control, with no issues.
.. I get the following error when executing the program:
Code: Select all
Number of relays to test: 8
Milliseconds to wait: 50
A serious error has occurred:
java.lang.ArrayIndexOutOfBoundsException: 128
   at com.pi4j.io.gpio.GpioProviderBase.getPinCache(GpioProviderBase.java:69)
   at com.pi4j.io.gpio.GpioProviderBase.export(GpioProviderBase.java:98)
   at com.pi4j.gpio.extension.mcp.MCP23008GpioProvider.export(MCP23008GpioProvider.java:127)
   at com.pi4j.io.gpio.GpioProviderBase.export(GpioProviderBase.java:79)
   at com.pi4j.io.gpio.impl.GpioPinImpl.export(GpioPinImpl.java:158)
   at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionPin(GpioControllerImpl.java:517)
   at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionDigitalOutputPin(GpioControllerImpl.java:669)
   at sfcountertester.SFCounterTester.<init>(SFCounterTester.java:93)
   at sftestsuite.SFTester.main(SFTester.java:71)
Expect: 17 counts for relay: Relay2
Expect: 16 counts for relay: Relay3
Expect: 15 counts for relay: Relay4
Expect: 14 counts for relay: Relay5
Expect: 13 counts for relay: Relay6
Expect: 12 counts for relay: Relay7
Expect: 11 counts for relay: Relay8
Exception in thread "Thread-1"
java.lang.RuntimeException: java.io.IOException: Error writing to /dev/i2c-1 at address 0x20 to address 0x9. Got -10001.
   at com.pi4j.gpio.extension.mcp.MCP23008GpioProvider.setState(MCP23008GpioProvider.java:203)
   at com.pi4j.io.gpio.impl.GpioPinImpl.setState(GpioPinImpl.java:325)
   at com.pi4j.io.gpio.impl.GpioControllerImpl.shutdown(GpioControllerImpl.java:939)
   at com.pi4j.io.gpio.impl.GpioControllerImpl$ShutdownHook.run(GpioControllerImpl.java:888)
Caused by: java.io.IOException: Error writing to /dev/i2c-1 at address 0x20 to address 0x9. Got -10001.
   at com.pi4j.io.i2c.impl.I2CDeviceImpl.write(I2CDeviceImpl.java:124)
   at com.pi4j.gpio.extension.mcp.MCP23008GpioProvider.setState(MCP23008GpioProvider.java:201)
   ... 3 more
run-remote:
BUILD SUCCESSFUL (total time: 29 seconds)
in addition I attach code:
Code: Select all
package sfcountertester;
import com.pi4j.gpio.extension.mcp.MCP23008GpioProvider;
import com.pi4j.gpio.extension.mcp.MCP23008Pin;
import com.pi4j.io.gpio.GpioController;
import com.pi4j.io.gpio.GpioFactory;
import com.pi4j.io.gpio.GpioPinDigitalOutput;
import com.pi4j.io.gpio.PinState;
import com.pi4j.io.i2c.I2CBus;
import java.io.IOException;
 * @author gproost
public class SFCounterTester implements Runnable {
    private int numRelays;
    private int minimumClicks = 10;
    private int delay = 100;
    // create gpio controller
    final GpioController gpio = GpioFactory.getInstance();
    // create custom MCP23008 GPIO provider
    final MCP23008GpioProvider gpioProvider;
    // relays
    static GpioPinDigitalOutput relay1;
    static GpioPinDigitalOutput relay2;
    static GpioPinDigitalOutput relay3;
    static GpioPinDigitalOutput relay4;
    static GpioPinDigitalOutput relay5;
    static GpioPinDigitalOutput relay6;
    static GpioPinDigitalOutput relay7;
    static GpioPinDigitalOutput relay8;
     * @param numRelays
     * @param delay
     * @throws InterruptedException
     * @throws java.io.IOException
    public SFCounterTester(int numRelays, int delay) throws InterruptedException, IOException {
        gpioProvider = new MCP23008GpioProvider(I2CBus.BUS_1, 0x20);
        try {
            this.numRelays = numRelays;
            this.delay = delay;
            if (numRelays >= 1) {
                relay1 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_00, "Relay8", PinState.LOW);
                relay1.setShutdownOptions(true, PinState.LOW);
            if (numRelays >= 2) {
                relay2 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_01, "Relay7", PinState.LOW);
                relay2.setShutdownOptions(true, PinState.LOW);
            if (numRelays >= 3) {
                relay3 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_02, "Relay6", PinState.LOW);
                relay3.setShutdownOptions(true, PinState.LOW);
            if (numRelays >= 4) {
                relay4 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_03, "Relay5", PinState.LOW);
                relay4.setShutdownOptions(true, PinState.LOW);
            if (numRelays >= 5) {
                relay5 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_04, "Relay4", PinState.LOW);
                relay5.setShutdownOptions(true, PinState.LOW);
            if (numRelays >= 6) {
                relay6 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_05, "Relay3", PinState.LOW);
                relay6.setShutdownOptions(true, PinState.LOW);
            if (numRelays >= 7) {
                relay7 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_06, "Relay2", PinState.LOW);
                relay7.setShutdownOptions(true, PinState.LOW);
            if (numRelays == 8) {
                relay8 = gpio.provisionDigitalOutputPin(gpioProvider, MCP23008Pin.GPIO_07, "Relay1", PinState.LOW);
                relay8.setShutdownOptions(true, PinState.LOW);
        } catch (Exception ex) {
            System.out.println("A serious error has occured:");
            ex.printStackTrace();
    @Override
    public void run() {
        switch (numRelays) {
            case 8:
                runTest(relay8, minimumClicks + 8, this.delay);
            case 7:
                runTest(relay7, minimumClicks + 7, this.delay);
            case 6:
                runTest(relay6, minimumClicks + 6, this.delay);
            case 5:
                runTest(relay5, minimumClicks + 5, this.delay);
            case 4:
                runTest(relay4, minimumClicks + 4, this.delay);
            case 3:
                runTest(relay3, minimumClicks + 3, this.delay);
            case 2:
                runTest(relay2, minimumClicks + 2, this.delay);
            case 1:
                runTest(relay1, minimumClicks + 1, this.delay);
        // get out gracefully
        gpioProvider.shutdown();
        //       gpio.shutdown();
     * @param pin
     * @param number
    private void runTest(GpioPinDigitalOutput pin, int number, int delay) {
        try {
            System.out.println("Expect: " + number + " counts for relay: " + pin.getName());
            for (int i = 0; i <= number - 1; i++) {
                gpio.setState(PinState.HIGH, pin);
                Thread.sleep(delay);
                gpio.setState(PinState.LOW, pin);
        } catch (Exception e) {
If anyone can help, I would appreciate it immensely.
Regards,
George.
John
Contact:
Re: UniPi and pi4j
Postby John » Sat Oct 10, 2015 3:38 pm
This looks like maybe a bug in the Pi4J Java code and not in the application.
As far as i known the Pi4J library caches the pinmodes at the moment they are being initialized just in case you re-initialize a pin it throws an exception.
The error is an error showing that a certain entry in an Java Array does not exist at position 128, and hence throws an index out of bounds exception. I would discuss this one with the Pi4J developer as it is the Pi4J lib throwing the exception.
George Proost
Re: UniPi and pi4j
Postby George Proost » Sun Oct 11, 2015 12:06 pm
Hi John,
Yes issue is pi4j .. pin caching..
Currently under snapshot-1.0.1 fails ... under version 1.0 works.
I need snapshot however due to improved serial behaviour.
I have contacted the developers.
Regards
George
John
Contact:
Re: UniPi and pi4j
Postby John » Sun Oct 11, 2015 6:43 pm
Hi George,
Have you tried jssc for serial connections? It controls both serial pins (using /dev/) and serial over usb. You would be able to use the 1.0 then.
Cheers,
John
George Proost
Re: UniPi and pi4j
Postby George Proost » Tue Oct 13, 2015 10:12 am
Thanks John,
I'll look into that.
George.
Return to “General discussion”
Who is online
