Humidity sensor for unipi that can work with evok or owfs ?
BlackSoll
Postby BlackSoll » Sat Aug 22, 2015 2:29 pm
Hi, i'm looking for a humidity sensor to connect to my unipi. Haven't found anything to your eshop........
Is this sensor suitable ?
Code: Select all
http://www.robotshop.com/eu/en/digital-temperature--humidity-sensor-with-stainless-steel-probe.html
Do you have anythink else to propose ? Will this work if i connect it to unipi 1wire ?
tomas_hora
Site Admin
Re: Humidity sensor for unipi that can work with evok or owfs ?
Postby tomas_hora » Mon Aug 24, 2015 7:46 am
our air humidity sensor for 1Wire network is on our todo list, however there are some solutions available online but it is not supported with evok (maybe fhem could work).
Your sensor is not a 1Wire device, so it can't be connected to the UniPi. However you could use the unused GPIOs of RPi and do it on your own.
BlackSoll
Postby BlackSoll » Tue Sep 01, 2015 10:16 am
What about this sensor ? Is it compatible ? If i plug it in the 1wire 8 port hub and using owfs will work ?
Code: Select all
https://www.modbusplc.com/zc/index.php?main_page=product_info&cPath=4_5_8&products_id=69&zenid=
tomas_hora
Site Admin
Postby tomas_hora » Tue Sep 01, 2015 2:53 pm
you would have to modify the connector because there is a RJ12 and completely different pinout than we use. Than you need to know if it is supported by the software you want to use.
We will publish our own humidity sensor that will be supported with at least the evok hopefully this year.
tenallero
Postby tenallero » Thu Sep 10, 2015 5:30 pm
So, meanwhile your humidity sensor arrives ... can I adapt any other 1-Wire sensor to Unipi?
If I use Evok, would the following sensors work? How to know previous to purchase?
http://www.hw-group.com/download/Humid-1Wire_FL_en.pdf
https://taaralabs.eu/1-wire-humidity-te ... re-sensor/
Thanks in advance
tomas_hora
Site Admin
Postby tomas_hora » Fri Sep 11, 2015 7:30 am
As I said before, our humidity sensor is on the way. Once I am done with some changes in the API I will start implementing the 1Wire huimdity sensors as well...
There are no details on the hwgorup pages but our sensors will be similar to the ones from taaralabs.
tenallero
Postby tenallero » Wed Oct 21, 2015 1:36 pm
I was not aware that some 1Wire humidity sensor were available at your shop.
I am talking about UNICA sensors (http://unipi.technology/product/unica-1wire-sensor/)
Perhaps I am wrong, but these UNICA sensors are not the humidity/temp sensors you are working on.
Aren´t they?
tomas_hora
Site Admin
Postby tomas_hora » Fri Oct 23, 2015 4:53 pm
we only resell these sensors from our partner but so far no software platform except FHEM maybe is compatible. Support to evok will be added in one month.
julien
Postby julien » Mon Jan 11, 2016 10:20 pm
what about evok update ? Is it working with the UNICA Modules you sale on the shop?
Julien
tomas_hora
Site Admin
Postby tomas_hora » Tue Jan 12, 2016 8:50 am
Still work in progress.... I will let you know once done.
Return to “Other Peripherals”
Who is online
